Konica Bizhub C451 cannot copy checks.........
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Have a customer that wants to copy some checks he receives but the message comes up "reproduction of this original may be prohibited" and you get a black page. Tried copying in black & white but unsuccessful. Wondering if there is a way to turn this off. He is not trying to copy currency (money) and I seem to remember some of our other customers with this model have the ability to copy checks and do not receive that message.
  • RRodgers
    • Jun 2009
    • 1947
    Re: Konica Bizhub C451 cannot copy checks.........
    Try reducing it to about 90% and see if that works.
    • blazebusiness
      • 1257
      Thanks for the reply, I will have him try that. Guess I was hoping for something that could be changed in security settings or in service mode under softswitches or something to allow that type of printing. Still, appreciate the response.......
      • RRodgers
        • Jun 2009
        • 1947
        Its probably reconizing a pattern that is trippong the copy protect, no way of getting around it. Sometime reducing image size and setting it to b/w works. Good kuck
        • Jazzwcs
          • Jun 2012
          • 40
          Copy protect is being triggered by the watermark being detected on check. This will happen when you trying to make a color copy. Switch to b&w printing and also try using the watermark function in application option to add copy watermark to copy.
          • Gift
            • Mar 2011
            • 2459
            It's not just banknotes that are prohibited but scanning to a pc and print the image afterwards might be an idea...
            • Zackuth
              • Aug 2009
              • 448
              I found this out last Thursday. A customer could not scan or copy a check in color, but could in b/w.
              If at first you don't succeed, redefine success
              • rrrohan
                • Sep 2011
                • 1977
                Didn't he read legal warning about it being against the law to photocopy cheques
                • Synaux
                  • Mar 2012
                  • 1224
                  The legalities are bullshit and hypocritical.
                  I do this all the time:
                  When I send a facsimile of a check I copy the check in order to facilitate to the feed on the fax machine (I do not have the fax option installed on my machines).
                  Either way, I just made a copy of two different checks as well as currency without any issues on a c550 (a c451). Someone sue me.
                  I don't know what their settings are, but I am running default settings...
                  • rrrohan
                    • Sep 2011
                    • 1977
                    i thought that copy protection required a upgrade kit of some sort
                    we have never had a cstomer that needed it so cant recall what it is.
                    but by default without any options i have photocopied money just as a test and it worked fine
                    • wseyller
                      • Sep 2012
                      • 1129
                      Had another tech call me yesterday and asked me for help which is funny because it was not long after I first read this thread. Said that customer could not scan a check on a bizhub with b&w or color. Had him try to make a b&w copy then scan the copy which worked.
                      I seem to remember it was an E series copier he was on but not certain
                      • blazebusiness
                        • 1257
                        He couldn't copy it in color or even in black & white mode. As per the advice given here by you all we sent an email to the customer telling him to try reducing the image and try and to copy it in black & white. Don't know if that worked as he,of course, never emailed us back to let us know. Thanks again for all the responses.
