C451 - color problem with feeder copy
  • pat
    • Mar 2007
    • 16
    Hi,
    I have a color problem but only if i copy trough the feeder (df 611).
    I printed the demo page which is good, when I copy it from the copyboard it's good but when I copy the same original with the feeder it's much lighter and some grey squares have a light orange color.
    First I checked the feeder position wich was ok
    I ran trough the feeder setup a few times with the same result
    Also I tried to range the RGB color setting for the feeder but it's still no good.
    any ideas?
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    Go into tech rep mode and run stabilizer in initalization mode. Then run gradation. Make sure all optics are clean.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • pat
      • Mar 2007
      • 16
      I tried that already and the copies made from the copyboard are fine so I wouldn't think it has anything to do with that, not?
      • laserman06
        • Dec 2007
        • 323
        I saw the following on Konica's site:
        Products Products:
        bizhub C650
        bizhub C550
        bizhub C451
        Options:
        DF-611
        Details Subject:
        DF-611, copies of originals fed through the RADF are light. Copies of originals placed on the glass are OK.
        Description:
        Solution:
        CAUSE: The machine memory is scrambled.
        SOLUTION: Reset the machine to factory defaults by performing the following:
        1. Press the Utility key.
        2. Press User Settings.
        3. Press Copier Settings.
        4. Press Default Copier Settings.
        5. Press Factory and OK.
        Details Subject:
        DF-611, copies are wavy and exhibit poor copy quality from the document feeder. Copies of originals placed on the glass are OK.
        Description:
        DF-611, copies of originals fed through the RADF are wavy and exhibit poor copy quality. Copies of originals placed on the glass are OK.
        Solution:
        CAUSE: Incorrect document feeder height.
        SOLUTION: Perform the RADF height adjustment as outlined in the Service Manual.
        Ps 46:10
        • Frostwolf
          • 71
          Documents run through the feeder are copied at 300 dpi, off the glass 600 dpi, that would account for some quality loss.
