After changing roller belt unit and fusing unit, says same to change belt and fusing
  • pakesp
    • Jul 2025
    [Error Code] After changing roller belt unit and fusing unit, says same to change belt and fusing
    Konica minolta d-color mf3000. It was showing message to change roller belt unit and fusing unit
    but i have changed both, but it is showing the same message
    and it is showing error 0094 also please help
  • Blizzoo
    • Aug 2013
    • 608
    Re: After changing roller belt unit and fusing unit, says same to change belt and fus
    http://www.copytechnet.com/forums/ko...nolta-c35.html
    • Max
      • Oct 2011
      • 559
      You dont have to replace the fuser or the belt as you can simply reset the counter via a service mode or administrator menu. Sorry cant remember which one exactly .
      • pakesp
        thanks for your reply
        now it is showing error 0094
        it is olivetti not konica minolta
        • Max
          • Oct 2011
          • 559
          same thing regardless c35=MF3000
          • wseyller
            • Sep 2012
            • 1129
            error code 0094 on a Konica Minolta C35
            See the above for your 0094 error. There are many other threads I know on this issue if you search it.
            Edit: just realized the same link was already posted in this thread.
