konica c20 add toner
  • DOE
    • Mar 2010
    • 258
    purchased a used c20 that said it was low on black toner. we did a refill and changed chip and was able to make 10 copies and then it quit and said add black toner again. bought a konica black toner installed it got 10 copies and again its asking to replace black toner. omly c20 we have so not real familiar with machine. thanks
  • habik
    • 2013
    Pull the toner out switch machine off then on then try reinstall when asked.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • mo0651
      • 1054
      Re: konica c20 add toner
      Sounds like the drum unit was depleted of toner . You will have to put in new drum and new toner at same time.
      • toner cartridge
        • Sep 2014
        • 33
        you can try to restall toner cartridge again..
        chip for toner cartridge, drum unit
        • DOE
          • Mar 2010
          • 258
          i installed new konica imaging unit and a new compatible toner got 10 copies then said it was out of toner again. have tried several toners and imaging units with same result
          chip for toner cartridge, drum unit[/QUOTE]
          • Hansoon
            • Sep 2007
            • 3391
            The toner entering port of the drum unit may be blocked cause the shutter does not open and/or the toner inside that port is hardened. Unfortunately as soon as the $#& machine believes that the toner cartridge is empty it writes this in the eprom of the toner cartridge blocking future use.
            You might try to get a single chip for the toner cartridge to get around this situation.
            Hans
