Bizhub C352 Magenta
  • ChipDi
    • 5
    [Misc] Bizhub C352 Magenta
    Form some reason we a using a lot of magenta toner.
    I just replace the Y,C,M IU. The machine is running the magenta toner trough the machine. There is magenta toner all over in the machine and filling up the waste toner. I put the old M IU in and it ran for awhile. but back to using magenta toner.
  • habik
    • 2013
    If they printing girlie stuff then there is your answer.
    Could be HV unit, bad IU, dirty IDC. Can you scan the listoutput ?
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • ChipDi
      • 5
      Re: Bizhub C352 Magenta
      Ok replaced the IU with an older one, but now I have code C2554, my State Confirmation, Level History 1, is TCR-M 14.65, the new one was TCR-m 2.79. I do belive the IU is bad.
