C364e Jams
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 90
    C364e Jams
    My C364e jams from tray 2 only. J20-02. Removed feed head and replaced rollers and clutches once, last go around, I swapped rollers and clutches with tray 1 with no difference. I have made sure all sensors are clean and the rest of the transport section works as it doesn't jam from anywhere else. Any ideas out there?
  • occus
    • 338
    Re: C364e Jams
    Replace the black(1.Version) or the grey(2.Version) vertical transport roller... with the 3.Version (new)
    The problem is known.
    • jwrycza
      • Sep 2013
      • 90
      Re: C364e Jams
      Is there a tech pub I can reference for the part number? I will search for one if you don't know.
      Thanks!
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: C364e Jams
        Latest field replacement black ribbed vertical transport roller part number is in the latest parts manual, or online.
        (and constantly on backorder for obvious reasons)
        • jwrycza
          • Sep 2013
          • 90
          Re: C364e Jams
          I did just find the bulletin and have ordered one. There are only 5 at Brooks though so, I am not hopeful of getting on anytime soon! Thanks for the help and I will let you know if it works!
          • occus
            • 338
            Re: C364e Jams
            We made our own roller by a roller manufacturer. Works perfect
            I can't wait for solutions which ar well known.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Re: C364e Jams
              now thats an interesting looking rolller!
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Re: C364e Jams
                field replacement black ribbed roller isnt the roller in the feed unit pictured, its off to the side and listed as a field replacement part.
                • giddyupngo
                  • Oct 2014
                  • 109
                  Re: C364e Jams
                  Thanks for the info. Had trouble finding the bulletin, as it is referenced to the C364e, but not the C284e.
                  It is bulletin number 9404
