Konica Minolta C250 Tray 2 not raising if too much paper - causing jam? ( 11" x 17")
  • patterson70
    • May 2010
    • 605
    Hello, loaded 11" x 17" in drawer 2 but having jam issues. Have to put just the right amount in or will jam if too much or say "replenish paper" if not enough. It appears maybe the white gear inside in the back that raises the paper in drawer 2 by raising the lever on the side of the paper tray is either failing or intermittently working. Has anyone seen this before? If I put just the right amount of 11" x 17" paper in the drawer it feeds fine, copies and prints look good. I can hear the motor working when I close the drawer but maybe it fails to raise up all the way due to the weight of the heavy ledger paper? If it is the motor/clutch is it a difficult repair? Thanks in advance.
