c5501
  • mike cooper
    • Sep 2014
    • 14
    c5501
    will not warm up any help
  • Mick01
    • Nov 2012
    • 362
    Re: c5501
    Hi,
    Are your fusing lamps turning on?
    Have you checked continuity of the lamps?
    Have you checked continuity of the Thermostats?
    Have you checked the connectors between the fusing unit and main body?
    Is your machine showing any SC codes?
    • mike cooper
      • Sep 2014
      • 14
      Re: c5501
      Originally posted by Mick01
      Hi,
      This machine is new to me only had it 2 weeks worked fine 1 week then will not warm up
      it shows no codes
      • Mick01
        • Nov 2012
        • 362
        Re: c5501
        Hi,
        If you are an end user I suggest you get a trained technician in to help you resolve this issue.
        Most likely will be a fault in the Fusing Unit or AC driver board. The list I gave you previously is what a technician will check to try and isolate the fault.
