bh c280 hard drive
  • mque@hvc.rr.com
    • Jul 2025
    bh c280 hard drive
    can anyone tell me if a computer hard drive can be used on a konica minolta bh c280 copier? your input will be greatly appreciated.
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    Re: bh c280 hard drive
    Yes you can however the machine can be picky and reject it too. Make sure you get the exact same specs or just slightly bigger and when you format it with bizhub it will only use what it needs. DO NOT GO TOO BIG, be close. Sometimes its trial and error (brands/exactly how big) like the USB sticks; the bizhubs are just... picky about it. Once you find one that works, stick with it.
    It does not matter how slowly you go as long as you do not stop. –Confucius
    • MCC-support
      • Jul 2014
      • 38
      Yes. It is the same with most brand MFD's. Rule of thumb: No smaller than orginal, no bigger than 2tb. I find WD HDD's to be the most reliable.
      Initialize the drive first in a Windows PC without formatting. Install in machine. For the C220 280 360, if possible, uninstall the HDD in service mode before removing it. After installing the new one, install it in service mode again and then do the logical format in the machine. (Don't do a Physical format unless you want to watch it for a couple hours )
      • laitang
        • Nov 2012
        • 627
