bizhub c452 stripes on black
  • JDR
    • Jan 2015
    • 82
    #16
    Re: bizhub c452 stripes on black
    Same issue there.
    issue.pdf
    I would have bet on HV PWB 1 but a previous message said bad fix.
    • Mr. Joshua
      • Nov 2011
      • 31
      #17
      Originally posted by imihm
      Hi there
      Replace the CCD assy
      For the less educated on here, this is nonsense. I can't stand watching time/effort wasted going down the wrong road.
      • Mally
        • Jun 2016
        • 5
        #18
        Howzit guys. Pitch lines is very difficult to correct and in all cases I've seen it never totally went away. But u can improve the lines drastically. The problem is caused because the k drum is engaged when making a greyscale print, which in test mode halftone is 1PC black. But u will notice a 4PC black is much better because all drums are engaged. In a 1PC print, the transfer belt is too loose because of the 1 drum only and it causes pitch lines. Therefore when all 4 drums are used the print looks better because the transfer belt is tighter. To improve this,choose 2 colour on your printer driver using black and blue. Pls note this will now be considered a colour print, so advise customer. Cool
        • habik
          • 2013
          #19
          Well done.
          Now wouldn't it be possible to adjust the slack on the paper loop so there is minimal drag like EarthKmTech suggessted?
          Firmwares HERE
