intermittent c5102 error bizhub c 353
  • brent
    • Nov 2008
    • 1214
    it has logged 13 of these errors. c 5102 and resets through the front cover. runs for a while. then does it again.
    anyone else seen this? I know the book says transport m1 motor and then printer control board.
    just don't want to replace anything unnecessary. any thoughts? thanks
    brent
  • scottybbb
    • Dec 2010
    • 126
    Re: intermittent c5102 error bizhub c 353
    Replacing transport motor always does the trick for me.
    • laitang
      • Nov 2012
      • 627
      Originally posted by brent
      ....just don't want to replace anything unnecessary. any thoughts? thanks
      brent
      Did you check Black PC drive sub sensor PS29 and PS30?
      • Imsdal
        • Aug 2009
        • 111
        I agree with scottybbb, is the brush motor that has failed, I have changed many of them, this the part nr: A02EM10301
        Cheers
        • brent
          • Nov 2008
          • 1214
          Cheers
          I will check this out. Thanks you guys!! Very appreciated
          brenr
          • paulrid
            • Nov 2011
            • 206
            Every time I have had a 5102 it's always been the m1 motor as said, but for some reason on the c353 they do seem to keep going for (sometimes) a while.
            paul.
            • brent
              • Nov 2008
              • 1214
              Motor is on order. Thank for all your help
              I'm glad we can all help eachother
              • brent
                • Nov 2008
                • 1214
                What a disassembly procedure. The first is the worst I didn't take the box sll the way off. Might be easier to have someone hold thst box and replace the motor. That is the only shortcut I seen Its all apart. And waiting for the ups giu in the morning !! Thx
                • brent
                  • Nov 2008
                  • 1214
                  well with your help I got it going this morning. the motor was bound up. it is quite the procedure for the first time for sure
                  anyways. thanks for the help guy guys.
                  brent
                  • Hansoon
                    • Sep 2007
                    • 3390
                    • brent
                      • Nov 2008
                      • 1214
                      [/QUOTE]
                      • toner cartridge
                        • Sep 2014
                        • 33
                        brent
                        yes, need to replace transport m1 motor and then printer control board
                        toner chip, copier part
                        • Hansoon
                          • Sep 2007
                          • 3390
                          Yesterday I had to do one again with a C5102 service code and this BH-C-353 also had the fax unit so even more screws to remove. I confess, that I left out as many screws as possible this time. The PWB box is barely holding to the machine LOL. Left the place with my pocket full of little screws. I'm getting too old for this crap......
                          I don't mind trouble shooting for hours or even a whole day to find a solution for a problem but don't come me with handling 40-billionzillion stupid screws for nothing.
                          Hans
                          • allan
                            RTFM!!
                            • 5462
                            Try to Swop 2 laser units on site just to check something on a C35.
                            Whatever
                            • brent
                              • Nov 2008
                              • 1214
                              I really appreciate the help I had here on the board. And yes. It had a bazillions of screws. I confess. I put all the screws back. And this was not a very fun fix
