C65hc dropping toner
  • Joseph.ARM
    • Jun 2013
    • 36
    I have a KM C65hc, and its randomly dropping specs of black toner. After start up the first couple prints look horrible, lines and streaks of black toner. After a few copies it clears up, but I still get black specs randomly dropped onto the sheet.
    I'm stumped. Any suggestions?
  • gurko_gg
    Prod.Line Technician
    • Sep 2011
    • 43
    Re: C65hc dropping toner
    Hello did you clean developing unit and toner filter assy?
    regards
    • Joseph.ARM
      • Jun 2013
      • 36
      Yes, the top of the developing unit was covered in toner. I cleaned out as much as I could. Could I have a blockage some where?
      • gurko_gg
        • Sep 2011
        • 43
        Can u share photo about problem
        regards
        • Joseph.ARM
          • Jun 2013
          • 36
          I apologize for the delay, after cleaning everything out I ran a few copies with out an issue.
          It was shut down over the weekend and fired it up again and received c-4522 on start up. I opened her up to clean the registration sensors and I found the top of the dv unit covered in toner again and the registration sensors as well.
          Photos attached. I'm in the process of cleaning everything up.
          • Joseph.ARM
            • Jun 2013
            • 36
            I pulled the registration assy as well. One of the three sensors was covered in toner. Photos attached.
            • gurko_gg
              • Sep 2011
              • 43
              [ATTACH=CONFIG]26623[/ATTACH][ATTACH=CONFIG]26624[/ATTACH][ATTACH=CONFIG]26625[/ATTACH][ATTACH=CONFIG]26626[/ATTACH]
              Can you swap drum and charging corona for magenta another color
              regards
              • Joseph.ARM
                • Jun 2013
                • 36
                Pulled transfer belt as well, the transfer section was loaded with toner.
                I have everything back together.
                Anyone have an idea what is causing this?
                • Joseph.ARM
                  • Jun 2013
                  • 36
                  Now I'm receiving c-2840 on start up "PGC sensor correction failure during maximum density control. The sensor is clean and the shutters are working, I watched them operate when I ran the output check for SD3.
