Auto Booklet Option
  • halbrandenburg
    Bypass Tray Expert
    • Sep 2011
    • 92
    Auto Booklet Option
    By default, on the Bizhub E series machines, when using the copier, if you choose to do a fold and center staple option, by default, the machine assumes the booklet option. Where is the setting to turn that option off so the booklet feature is not implemented automatically? I don't have a saddle stitch finisher available to dig around.
  • emujo
    • Jun 2009
    • 3009
    Re: Auto Booklet Option
    Look under "functions" for booklet. This may be defaulted to on. Emujo
    • halbrandenburg
      Bypass Tray Expert
      • Sep 2011
      • 92
      Thanks EMUJO. I know the option is ON, I just don't know where the option is located to turn it off as a default, somewhere in the USER SETTINGS I reckion. But I did not have a machine to look for it. Not sure where the "functions" is you mention. I'll post the answer when I get access to a finisher that folds and staples.
      • habik
        • 2013
        Copy settings>factory default ( instead of current settings)
        Sent from my iDon't believe in marketing device using Tapatalk
        Firmwares HERE
        • halbrandenburg
          Bypass Tray Expert
          • Sep 2011
          • 92
          Hmmmmm
          • B0265
            • Jan 2007
            • 718
            Utility - User Settings - Copier Settings - Auto Booklet Selection for Saddle Stitching
            • emujo
              • Jun 2009
              • 3009
              Set the copier up the way you want it, then go to user mode, copier settings, default settings and choose current settings. Emujo
              • halbrandenburg
                Bypass Tray Expert
                • Sep 2011
                • 92
                That works too...
