I have a C500 with intermittent J72-29 codes. Any suggestions.
C500 intermittent j72-29
Hi,
Ive also had like that problem to, the wiring loom is to short there is a mod for it, a longer wiring loom.
Also had a problem with intermittent jams with that code also and it was due to the solenoid beside the anticurl roller,the wire to the solenoid was damaged,replaced solenoid and it worked.Comment
Many thanks, gentleman. I too went to pull of the connector to the switch and the red wire came right off. Spliced a new connector, works just like a champ.
Again I thank you and my customer thanks you
Blessings,
RobThe family that prays together, stays together!
Smile God created you and He doesn't make mistakes!
Relax, God IS in control!
Be still and know that I am God
Ps 46:10Comment
