Scanning documents with bizhub 363
  • jbeteta
    • Jul 2025
    Hi,
    Is there any quantity limits of sheets A4 (pieces of paper) using bizhub363 when scanning?
    I'm using scan-to-me (email) function and it only allows me to scan 15 pieces of papers. If I try to put and scan more sheets, printer will show that there was an error and couldn't send me an email with Pdf file
    I don't know if my email inbox size limit is the restriction or it is the bizhub 363 printer.
    Last question: If I need to scan 200 sheets or pieces of paper, and email that PDF file is not possible, would be it possible to save it directly to a USB disk while scanning?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Scanning documents with bizhub 363
    Approx 15 pages is about right if the unit does not have a hdd.
    Separate scan will allow more than what will fit in adf at one time but you are still limited without an hdd.
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Also your email settings may have a limit set on them, your email provider I'm sure has a cap on file size as well, as for scanning to USB by default I believe saving a document to USB is on by default but print from USB is off by default. Check the External Memory settings under Administrator settings and User Box settings.
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • emujo
        • Jun 2009
        • 3009
        PDF Compact will also reduce the file size (by about 80%). Emujo
