Konica Minolta C451 Paper Jam - Misfeed
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C451 Paper Jam - Misfeed
    When we turn on the copier. It gives an error of Misfeed in Tray 4. When open and close LC1 Tray in Tray 4. It disappears. Again if we switch off and on the copier it appears.
    We have changed the LC1 Tray Sensor inside the copier. Please find the attached Pics.FullSizeRender (1).jpgFullSizeRender.jpg
    Please advise.
    Thanks and Kind Regards,
    Mearmi
  • Imsdal
    • Aug 2009
    • 111
    Re: Konica Minolta C451 Paper Jam - Misfeed
    I think I had this problem before and the problem was a piece of paper stuck in the contact inside the machine for the papaertray.
    See if you can use a flashlight and clean the contact, hope this will help.
    imsdal
    • mearmi
      • Oct 2010
      • 346
      imsdal
      Bro what do u think
      i have checked everything throughly
      it is been 20 days I m trying to solve this problem and v simply u left everything on a piece of paper
      thanks mate
      • habik
        • 2013
        What is the mileage on your machine?
        I had a shaved spindle on drive motor and some gears that would not mesh for Tray 3.4
        Take the back covers off and have a look at the drive.
        Firmwares HERE
        • darry1322
          • Oct 2010
          • 817
          Originally posted by mearmi
          Bro what do u think
          thanks mate
          Maybe I'm getting the wrong vibe from this, but you seem to be treating someone trying to help you pretty harshly. Good luck with that.
          • emujo
            • Jun 2009
            • 3009
            Wow, down machine for 20+ days, and all you've done is replace a sensor??? That's pitiful, but not as pitiful as bitching at the guy that attempted to assist you. Good luck "Bro". Emujo
            BTW "LC1 tray sensor" is not listed in the parts manual so I'm not even sure what you replaced
            • wseyller
              • Sep 2012
              • 1129
              Need to check the state confirmation of the sensors in service mode.
              • mearmi
                • Oct 2010
                • 346
                imsdal
                • Imsdal
                  • Aug 2009
                  • 111
                  Hello Mearmi..
                  Was a piece of paper stuck in the contact?
                  Cheers
                  • mearmi
                    • Oct 2010
                    • 346
                    Hello Mearmi..
                    Cheers
                    Thanks for your message.
                    i replaced the drive assembly in cassette 4 and now all good.
                    i think one of the sensor in the drive is defective.
                    anyways thanks for your help
