Konica 7145 Error Code !Help!
  • RookieTech
    • Jun 2008
    • 46
    F52-9 Hard Drive Fan: Is this just dirty or their a fan that needs to be replaced? If so, what is the part number?
    thank you.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    That fan is a very small fan, unless you have drilled holes in your cover like we do it just blows against the cover.It could be plugged up or the connector may be loose. If you check it and it appears to running fine then it could be your main bd, thats what the fan pluigs into.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • pepper38_cnd
      • Aug 2005
      • 1075
      I don't see that fan in the parts manual, it comes with the HD103, the hard drive fails much mor often than the fan, so we have always had extra fans. Never had to order one.
      • CMB
        KonicaMinolta Tech.
        • Mar 2005
        • 457
        Subject:
        DESCRIPTION:
        F52-9
        Description:
        F52-9
        Solution:
        SOLUTION:
        CAUSE:
        HD-103 Cooling Fan abnormality
        SOLUTION:
        Replace Cooling Fan (p/n 13HJ80520), or System Control Board
