Konica Minolta C252 Data Light Keep on Flashing
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C252 Data Light Keep on Flashing
    Konica Minolta C252 Date Light Keeps on Flashing sometimes. Client has to off and on the copier. They are getting this problem every 3-4 days.
    Please advise.
    Thanks and Regards,
    Mearmi
  • emujo
    • Jun 2009
    • 3009
    Re: Konica Minolta C252 Data Light Keep on Flashing
    This MFP is pretty old, you may be getting print data the it can't understand. Cycling power is clearing the RAM but when that job is sent again you get the same symptom. Trouble areas could be;
    1. Printing from the web
    2. Driver/OS mismatch
    3. PS files using the PCL driver
    As always, a firmware update is not a bad idea. EMujo
    • mearmi
      • Oct 2010
      • 346
      Thanks a lot for your reply.
      how to update the firmware?
      thanks
      • pauloskar
        • Dec 2014
        • 6
        CAN I GET THE FIRMWARE UPDATE FOR BIZHUB C252
        THANKS IN ADVANCE
        pauloskar@gmail.com
        • allan
          RTFM!!
          • 5462
          If you use wireshark it would identify the IP the data is coming from. Had a B36 with same problem.
          Whatever
