Konica Minolta BIZ HUB 500
  • dclair123
    • Jul 2025
    I have a 54000 copy Konica Minolta Biz Hub 500 that when powering has a blue screen and will not cycle. I have read that you need to re install Ganges 20 Boot which I have done several times and the data light flashes fast and then slows to a slower flash. According to
    the tech specs it says that the unit after receiving the new boot that it the screen will go dark and then bump so that you can re install the firm ware. I have bin 20000 for the boot as well as the bin 25000 and bin 31000 files I am using a parallel as it states and still no
    results.... is it a bad OACB board and if it is what is the part number that I need to look for I have found several from 50GA -9200 all the way to 50GA -930 4O which one should I use and is it the OACB if it will not take the boot software?? It appears that the system is communicating as the data lite is flashing but cannot tell? HELP!!!!
