Need some help testing an issue, Bizhub 754E while its processing a print job mainly a big job if you go into scan mode the machine has a message that says "know scanning or know copying". While this message shows the machine is unusable does not take in originals "DOES NOT MULTITASK". This machine is hooked up to Dispatcher Pheonix and Equitrac, I've also tried to test and it exhibits the same issue on other bizhub 745e with papercut "DOES NO MULITASK", also tested a machine stand alone without any solutions hooked up to it Bizhub 654E and machine "MULTITASKS FINE".
Could anyone try out MULTITASKING on these machines? All our machines are hooked up to 3rd party solutions, I need some results from stand alone bizhubs 754E models machines.
TEST: send a print job a service manual PDF then while it's processing try going into scan mode and scan something
Note: I've tested this on Bizhub 545e with solutions hooked up and it MULTITASKED FINE.
