Konica bizhub 1050 developr change
  • acsolutions
    • Jun 2010
    • 519
    [Misc] Konica bizhub 1050 developr change
    Hello, Is there a developer calibration when installing new developer? Just replacing Drum, blade and developer and go through the Drum Peculiarity adjustments! Also what is the cartridge set mode, and when is it done? Thanks
  • allan
    RTFM!!
    • 5462
    Re: Konica bizhub 1050 developr change
    Use the manual. List of adjustment items. This gives u the adjustment procedure when changing spares. This machine has excellent process control it would fix the toner level by itself. So even if you just chuck the dev in there it should sort it self out.
    Whatever
    • minimerlin
      • 851
      The Cartridge Set mode is to give a good mix and tribo charge to the developer. I normally do this first, before any of the other settings are done. My theory is that you are better off getting a full mix before allowing black patches etc to be produced!
      Please do not PM me without asking first.
      • acsolutions
        • Jun 2010
        • 519
        Thanks, I will give that a try!
