Disassembling Konica Minolta C451 for moving - Urgent Help
  • GStu
    • Aug 2025
    Hi Everyone, I have to move a Konica Minolta C451 out of a doorway and need to take it apart in 3 pieces to get it out of the door. Can anyone tell me how to take it apart and also what tools I will need to take it apart please as I need to find out rather urgently.
    If anyone has a video of how to do this it would be very helpful.
    Thank you and I look forward to your replies.
  • bigwul
    • Jun 2014
    • 60
    Re: Disassembling Konica Minolta C451 for moving - Urgent Help
    What's on it that you want to remove? I assume perhaps finisher and LCF - ??
    • bigwul
      • Jun 2014
      • 60
      I also guess not that urgent - s'pose you were away getting a decent Phillips or Pozidrive screwdriver.......
      • GStu
        Hello thanks for replying, here is a picture of it, as not sure about what's attached, i'm not a techy you see.
        • GStu
          Yes still urgent, just was away from my desk.
          • bigwul
            • Jun 2014
            • 60
            Usually to remove a finisher - open as to clear a paper jam - moving it away from the main machine - and you should be able to see the brackets etc. that hold it on.....remove a couple of screws....and should be fairly obvious...If you are going to disconnect any cables etc. make sure the machine is powered down - remove AC cable to be 100% sure - not doing so can destroy PCBs in some machines.
            Not sure what else you want to remove - I can move machines like yours complete - through a standard door opening.
