C284e Printing blue or cyan always
  • mphile
    • May 2011
    • 29
    [Misc] C284e Printing blue or cyan always
    Hello to all,
    I have got this C284e MFP its printing cyan(blue) all the time even when making black and white copies they come in cyan. I have done gradation on the machine and it comes out with cyan where there must be black. What could be the problem. Machine is two months on the field still new!.
  • emujo
    • Jun 2009
    • 3009
    Re: C284e Printing blue or cyan always
    Could be the Cyan developer, the X-fer belt, or a HVT issue. If you are a user, place a service call. Emujo
    • mphile
      • May 2011
      • 29
      Thanks will try and replace the high voltage board and see what happens.
      • minimerlin
        • 851
        Block a section of the laser path to the cyan drum..if this gives a white area strip on the print, then it is more likely to be a faulty print head.
        Please do not PM me without asking first.
        • allan
          RTFM!!
          • 5462
          Is Half-tones ok CMYK?
          Whatever
          • mphile
            • May 2011
            • 29
            Thanks for your help guys, the half-tones are 100% fine on all the colours.
            • hotfuser
              • 180
              is there any black in the copies at all?
              • mphile
                • May 2011
                • 29
                Either you print or copy there is no sign of black not even a small line. I have changed the High Voltage Board but its still giving me the blue prints.
                • hotfuser
                  • 180
                  please tell me you have checked that they have not put cyan toner in the black toner slot as i have customers force them in and cause this problem.
                  • wseyller
                    • Sep 2012
                    • 1129
                    I had a customer get the cyan toner in the black slot and all black print had cyan in it. Take the black developer unit out and see if the roller has cyan toner on it. I had to remove the sub hopper and clean it out then with the correct toner I ran about 50 black halftone pages and it cleared it up without having to replace the black Dev unit.
                    • PeterG
                      • Jul 2008
                      • 177
                      I have a feeling that you are "on the money". I have had this before.
                      Amazing how "persistent" customers can be if something doesn't fit.
                      • allan
                        RTFM!!
                        • 5462
                        Redo all the steps in the main body setup booklet. but that is for those lines.
                        Whatever
                        • habik
                          • 2013
                          The only solution is to make the toner cups in the relevant colour but I think, there will be one or two color blind whos force will be with them at that particular moment. Nice catch guys!
                          Sent from my iDon't believe in marketing device using Tapatalk
                          Firmwares HERE
                          • mphile
                            • May 2011
                            • 29
                            Problem solved,for me its a different storry, instead of the customer swapping toners, its the technician who was setting up the machine in the workshop before it went to the field. He put the cyan toner on the black toner slot and the the black on the cyan slot(how crazy can some people we trust with new machines and call them technicians can be, but I forgive Him without Him asking for forgiveness, lets call it a mistake ). Thank you all for your help(mostly Hotfuser and Wseyller).
