doc feeder df 621 with a c 8107 code
  • brent
    • Nov 2008
    • 1213
    I know it is the cleaning mechanism in the doc feeder. I tried to just disable it. no dice the feeder is completely down
    any ideas on what it may be?
    brent
  • raulblanco
    • Apr 2014
    • 8
    Re: doc feeder df 621 with a c 8107 code
    brent
    Try checking the PS13 (sensor check) if the sensor is working, would prove the M4 has changed. Also you can fail the board of adf.
      • 14757
      Have you tried just blowing out the sensor? I find most times the simplest solution is the is right solution. lol
