Hi guys, I have a B950, on the lcd the machine says " machine warming up'' and in a blue highlighted block it says '' now correcting please wait'' does anybody have an idea what could be causing this. If I go into service mode from start up the machine prints from the engine. Any help please reply.
B950
Re: B950
Hi Allen, thank you for the advise, ok Im running the adjustments now, auto maximum denisty adjustment just keeps running. Do you reckon developer and drum change will solve this?Comment
Re: B950
Try the developer first, maybe the developer unit. It could be the drum, but I would bet its probably the sensor under the drum first.Comment
Re: B950
Hi Allen, ok I have established the problem, it was from my developer tank, tank is not rotating probably.The drum is also in bad condition so I reckon I will replace the drum too. Once again thank you for your advise.Comment
Re: B950
It is silly that the machine does not time out and give an error B600/601 is famous for the now warming up thing. and it could be any thing that stops the creation of the patch or the reading of it. I had bad drums bad dev broken gears bad sensors and broken drum connector cause the same problem "now warming up"WhateverComment
Re: B950
Hi Allan, the developer tank has 20000000 prints on and is very stiff if you try to turn the gears, the drum was also in bad shape seeing that the developer couldnt rotate probably against it. As soon as I receive my spares I will replace systematically and will post the results here for you guys. Once again thank you to all for the adviseComment
