hello
I have a problem with my CF5001. When I plug in network cable into the fiery's RJ45, the "controller" icon from the screen disappear and the printer mode (fiery) is disable.
After this plugin I can use my CF5001 only in copy-mode. I must turn off the copier to enable the printer mode (fiery).
I changed my network switch, I used a crossover cable direct from my computer but without changes.
In this moment I print only with the parallel port.
Do you know this problem? any solutions?
Thank you!
Thank you!
