The Bizhub is connected on my LAN and it is recognized like a printer. I can set it over LAN, no problem. Just a little problem with the printer driver, but i solve it, installing a PCL5c Driver. The problem is,that it doesn't recognize and work the scanner. Neither from PC, Neither over the Bizhub. Any Help?
My Windows xp, doesn't recognize scanner of my Bizhub c350
Re: My Windows xp, doesn't recognize scanner of my Bizhub c350
You need to create a folder on your computer,share it and give permissions. Go to address book of the copier via web browser using the IP adress you have given it. Input IP address of the PC you are scanning to or a host name. Point to a folder you created ie (scans) input authentication credentials and you done. -
You need to create a folder on your computer,share it and give permissions. Go to address book of the copier via web browser using the IP adress you have given it. Input IP address of the PC you are scanning to or a host name. Point to a folder you created ie (scans) input authentication credentials and you done.Comment
sure you can guide on how to http://www.copytechnet.com/forums/ko...an-folder.htmlComment
From KonicaMinolta SSD :The bizhub C350 does not support scan to SMB it supports scan to FTP. When entering the FTP server information the TCP/IP address of the FTP server must be used.
SPECIAL NOTE: Solution contribution by Gregg Gallant, Production Print/SSDComment
I bet the OP is trying to see the scanner as a twain device. Which I wouldn't even use over FTP unless it was for a specific purpose. Not even sure this model has a twain driver available. Too lazy to look.Comment
Easiest way is to scan to Ftp
-copier must be wired in network
-use ftputility app installed on each computer you wanna set it to scan,make sure add it in exception list on firewall
-create a scan folder on each computer,regiter it in ftp settings
-log in mfp pagescope ->scan->new registration->ftp->set Host address of PC if DHCP is on->file path "/" "\" or "." and anonymous on.Defects are simple, our mind is complicatedComment
Thank you, Blizzoo . I made it. Just some settings remain to work, perfectly. With this problem, i have finished. the next problem is with P-28 Machine status,AIDC back sensor, how will i find it to clean.Comment
