konica c250 c-3461 code
  • DOE
    • Mar 2010
    • 258
    have a konica c250 that needed a fuser and a imaging unit. i was able to get a 100 ma fuse and replaced on fuser. the fuser message went away and just had replace imaging unit. put new chip on unit and then i got the c3461 code. i dont have a service manual so not sure if this is a fuser or a imaging unit problem. any help would be appreciated. although replace fuser went off i can see when i open and close front door that it says replace fuser soon. it should still work even with this message.
  • darry1322
    • Oct 2010
    • 817
    Re: konica c250 c-3461 code
    New Fusing Unit New Article
    Release •
    A new installation is not detected when a new
    Fusing Unit is installed.
    1. Check the Fusing Unit for correct installa-
    tion (whether it is secured in position). — —
    2. Check the Fusing Unit, PWB-M for proper
    connection and correct or change as nec-
    essary. — —
    3. Reinstall Fusing Unit — —
    4. Change Fusing Unit — —
    5. Change PWB-M
    • Blizzoo
      • Aug 2013
      • 610
      Put a 1/16F pico fuse or 63mA wire type,not from glass...100mA is to high.
