bizhub 1050 sc 21-07
  • costel fasola
    • Jun 2010
    • 69
    at start sc 21-07
    i try dipsw- 3-3 -1
    3-4- 1
    and 6-2-1
    looks like "ready to copy" but if i try to cpoy is sc 95-01
    if i try to do hv ajunstment : error adjustment
    any ideea?
  • Luther
    • May 2006
    • 682
    Re: bizhub 1050 sc 21-07
    Fan
    abnormality
    SC95-01 The EM signal is found abnormal a
    specified period of time after the
    ADU cooling fans /1 (FM14), /2
    (FM15) and /3 (FM13), the sensor
    cooling fan (FM16) and the registration
    cooling fan (FM17) turn on.
    And the signal is still found abnormal
    a specified period of time after
    it turns on again after turning off,
    and the door close of the door
    open/close sensors /1 (PS1) and /
    2 (PS2) and the PF door open/
    close sensor (PS70) has been
    detected 10 times in a row.
    ADU drive board /1
    (ADJDB1)
    ADU cooling fan /1 (FM14), /
    2 (FM15), /3 (FM13)
    Sensor cooling fan (FM16)
    Registration cooling fan
    (FM17)
    21-07 is the transfer cleaning motor.either the cleaner is not moving or the motor is bad
    • laitang
      • Nov 2012
      • 627
      • costel fasola
        • Jun 2010
        • 69
        Originally posted by Luther
        Fan
        abnormality
        ADU drive board /1
        (ADJDB1)
        2 (FM15), /3 (FM13)
        (FM17)
        Still not work. i try change aduboard, hv board on adu , cleaning motor, transferasist motor. Same thing.
        I try dpsw 3-3-1 3-4-1 and 6-2-1. Machine enter in "ready to copy" and in first page on print or copy go's in sc 95-01.
        If i try to do hv ajustement ( with sw 3-3-1 3-4-1 6-2-1 ) : transfer error.
        in state confirmation cleaning motor dont work with good motor from a god machine
        • costel fasola
          • Jun 2010
          • 69
          back to the issue. I changed to another copier Adu Adu unit. f is running fine on another machine. I guess the problem is something behind the copier can PRCB. got off PRCB I checked the ICP sites and have not found anything burned. I put it back and now surprise. A new code 93-01. all Adu something to the unit.
          advice do you have?
