DF-621 B363 scanning jam
  • allan
    RTFM!!
    • 5462
    [Misc] DF-621 B363 scanning jam
    When you make copies the DF works fine, but scanning the DF registers a jam on the last page fed thru. If i set the scanning res from 200X200 to 300X300 it works intermittently and at 400x400 the scanning works fine. Did someone come across this problem before? Everything on the DF looks ok. must be something that moves to slow?
    Whatever
  • habik
    • 2013
    Re: DF-621 B363 scanning jam
    I'll bet in service mode adf feed test it won't jam once, right?
    Flash with firmware. Even the same one. It helped me once.
    What jam codes you getting?
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • mo0651
      • 1054
      Had 1 doing this and reset tension on the belt and motor . It helped us.
      • allan
        RTFM!!
        • 5462
        I was in a bit of a hurry the work around worked so i never looked at the jam code. Only after a while at the next customer i realized i should have taken the code down. With a previous machine i did do the firmware newest base ver with no luck. I will check the passage test as well. I will only be back at that customer in 2 weeks time. I will get around to this to check. Thx
        Whatever
        • emujo
          • Jun 2009
          • 3009
          There was a bulletin about this issue, the MFP scans at slightly different speeds during copy and scan modes. It required a firmware update, (special) and a change to one of the ADF sensor flags. If I can find the exact bulletin, I'll try and post it. Emujo
          Update, bulletin #
          TAUS1200978EN
          Entrance sensor flag is worn, or The empty sensor lever interferes with the separation guide
          due to Left Cover position. Consequently, return of the lever to the
          original position is delayed and a timing error occurs.
          Note:
          This problem is more likely to occur with high speed scanning (300/400
          dpi) such as Scan to SMB. With normal copy scanning, problem occurrence
          is low as the scan speed is slower (600 dpi).
          • allan
            RTFM!!
            • 5462
            Thanks a lot i will hunt down the firmware. The portal we have to use is an unorganized mess to it is discouraging look for anything. the TAD refs helps a lot.
            Whatever
            • fixthecopier
              ALIEN OVERLORD
              • 4714
              I had the exact problem you are describing on a c-203. I am not sure if speeds are different for scan vs copy, because logically it should jam for both. For me , I found the entry paper detect actuator sticking, which explains why it waits til the last page to jam. Until it gets to that point, it constantly detects paper.
              • emujo
                • Jun 2009
                • 3009
                Disregard the firmware post, there is nothing for this issue. And yes, the ADF does operate at different speeds when scanning/copying. Watch it yourself at 600 dpi scans versus plain paper copies. Emujo
                • antone
                  • Oct 2014
                  • 344
                  Exit senor
                  • Kidaver
                    Ghoulscout
                    • Apr 2011
                    • 912
                    There are also TAD's for installing some spacers on the DF cover hinge, and adjusting the reading motor tension. Also modified Lever assemblies in the feed system with new springs in them.
                    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
