Bizhub C552 - questions / help
  • ECA
    • Dec 2014
    • 61
    Dry Lubricant Spray | PTFE Dry Lube & Solid Lubricants for Corrosion
    Looks like the AF sensor (up and down pin on the flat bed is not working) any way to fix?? or is new sensor required?
    • allan
      RTFM!!
      • 5459
      Re: Bizhub C552 - questions / help
      there is a whole bulletin for the noise on the fuser. Tried that with all kinds of lubricants and noise would return shortly. Ear plugs is the answer.
      Whatever
      • ECA
        • Dec 2014
        • 61
        Have done the power saving feature recommendation of. power save to inmediatally option instead of standard. works good
        Just need some lub to sort it out properly
        as for the ADF issue. im a bit stumped....
        the ADF open sensors and the flat bed vertical rod sensor seem to work. i thought it was the flat bed sensor. so testing it manually, still makes the scanner wake up...
        where is the sensor "DF open" in the service mode found?
        • habik
          • 2013
          #19
          It suppose to wake the scanner.
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
          • habik
            • 2013
            #20
            Originally posted by EarthKmTech
            You realise that version assembly has been superseded to the now black roller version ? the c452 series part number fits and works in the c451 series too.
            Has it been superseded due to squeaks or different matter? Haven't noticed any part bulletin.
            Firmwares HERE
            • ECA
              • Dec 2014
              • 61
              #21
              where is this sensor...
              thats the one causing the machine to think the ADF is open?
              So i can't insert any paper into the ADF, as it will say the compartment is open :/
              • emujo
                • Jun 2009
                • 3009
                #22
                Rs201 location.pdf
                Here you go..Emujo
                • ECA
                  • Dec 2014
                  • 61
                  #23
                  Originally posted by emujo
                  [ATTACH]27393[/ATTACH]
                  Here you go..Emujo
                  Awesome thanks
                  hidden magnet switch wasn't lined up with top.
                  all fixed, just the squeak to go.
                  thank you for all your help.
                  no doubt i'll be back
                  • emujo
                    • Jun 2009
                    • 3009
                    #24
                    Who'd have thought!!! Emujo
