C-0204 error on C350
  • ismail
    • Nov 2014
    • 34
    I had this error 2 weeks ago but it turned ok. now i have the same error again and it is not fixing and i can't do nothing. I look at second tray and first tray and there is no paper jam. i looked carefully inside the right door and there is no paper or anything jammed there also. Where i must i look? Any suggestion?
  • laitang
    • Nov 2012
    • 627
    Re: C-0204 error on C350
    C0204 Detail:
    Yellow PC Drum Charge Corona malfunction
    Relevant Electrical Parts:
    - Imaging Unit /Y
    - High Voltage Unit/1 (HV1)
    - Control Board (PWB-MC
    Procedures:
    1/ Check the Imaging Unit contact and correct or clean as necessary.
    2/ Check the HV1 contact and correct or clean as necessary.
    3/ Change Imaging Unit.
    4/ Change HV1.
    5/ Change PWB-MC
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      its almost always a bent needle on the charge electrode stabbing into the cleaner. I have had long hair end up in there before too. (not mine)
      • ismail
        • Nov 2014
        • 34
        can you navigate me, where is that?
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          inside the relevant imaging unit.
          in this case - yellow.
          • ismail
            • Nov 2014
            • 34
            thanks for your suggestion. i took out the yellow IU, open it and clean it but not fixed. any other suggestion?
            • ismail
              • Nov 2014
              • 34
              Fixed. i don't know how, but it is ok. i pull out the yellow IU several times, and it get fixed when i pulled the waste box out and in. i dont know if there is something about that two, but after is ok . Now i have the C-0F3A. And as i see, it is worse. any solution for that?
