C353 updating firmware
+ More Options
Posts
  • paulrid
    • Nov 2011
    • 206
    Hi all,
    dont worry I'm not asking for anything but advise I have (after lots of looking) found the the firmware for c203/253/353 and 280/360 from the CSES site. I have successfully updated them all to the end of life version but the C353 gives a NG error For the MFP, but I can then go back to a non end of life version. I have tried different CF cards and even bought another 128mb new one, all give this error.
    My question is is the NG error something to do with firmware versions? If so do you know of a list of firmware for each machine and release date? I have looked for this but as I said before I struggle with CSES.
    paul.
  • emujo
    • Jun 2009
    • 3009
    Re: C353 updating firmware
    Latest release for this family is R6 from 5/19/2009. The firmware is model specific, R6-G00, G10, G20 (C353, C253, C203 respectively) R6 includes the EOL softswitches. Hope this helps. Emujo
    • paulrid
      • Nov 2011
      • 206
      Thanks for the quick reply emujo,
      the firmware I'm using is ao2eoyo-foo-gp4-r6 which is the one on the release from Konica which seems to be the correct one. Perhaps it's just one of those things, I have other c353s I can try when I get them in the workshop.
      thanks Paul.
      • emujo
        • Jun 2009
        • 3009
        Model:bizhub C353/C253/C203
        MFP Firmware Ver. GP4-R6, GQ4-R6, GR4-R6
        Subject: If the Fax Function Parameter is initialized, the Enter Power Save Mode Setting is changed from "Immediately" to
        "Normal
        This is a special firmware, try finding the G00-R6. Emujo
        • paulrid
          • Nov 2011
          • 206
          "Normal
          Thanks again, that makes sense,I'll find it and let you know.
          paul.
          • paulrid
            • Nov 2011
            • 206
            Hi emujo,
            i couldn't find that firmware but I found other firmware which worked, thinking about it now I suppose the first one didn't work as it had a fix for fax and the machine I was testing it on didn't have a fax, silly me
            paul.
