Just wondering if anyone came across a single staple issue on C650+FS608?
Two staples all day long. Single/Corner misaligned staple. Had a closer look. The swivel back-plate (clincher) for stapler doesn't reach upper position. There isn't (or I have't seen one) a sensor for the upper(corner) position. Only for the lower HP. So my understanding is that it is run to the upper(corner) by step count without any validation of arrival. The stapler side does reach this position, the clincher side does only 80-85% of the journey causing the issue. Have swapped motors from nearby section, made no difference. Wanted to re-flash firmware with CF but my laptop came with blue screen of death. So had to abort mission and attack next day, just wanted to get armed with some helpful, experience information for my next visit in few hours.
Motor M4 unplugged - gives C1107 as it should.
Replaced and plugged in another M4 no difference
Meshing is good.
PS14 - I/0 check good"passed"
Thank you
Suspecting FSDB but praying it is just FW. Don't have spare boards
Sent from my iDon't believe in marketing device using Tapatalk
Meshing is good.
Thank you
