Customer has authentication activated for the BH-423 for use as copier and printer. This works well for both. However when authentication is set up, the normal use of an USB-Stick for printing and scanning from and to that stick is inhibited, it shows:
"External memory has been detected (installed). Currently, this feature cannot be used."
If authentication is off the same stick can be used for both printing and scanning.
Did I overlook something or is there a limitation from this otherwise fine machine?
Hans
Hans
