AirPrint
  • allan
    RTFM!!
    • 5462
    AirPrint
    Hi
    Any body tried the airprint function on the new CXXXe loaded with J6 firmware?
    Whatever
  • occus
    • 338
    Re: AirPrint
    No, i can't because of the "only for webbrowser " limitation.
    I'm wondering if i get trouble when i use this firmware for machines without the LK-Option.
    Airprint should be more comfortable than the Konicaminolta app... direct print from default mail app...
    I'm note a apple user.
    • allan
      RTFM!!
      • 5462
      Re: AirPrint
      Ok I loaded the new J6 firmware. Had a struggle to figure out how to activate the feature. After loading that firmware I had to change the function version from ver 3 to version 6 using bit switch 25 changed from HEX20 to HEX50 if all is well then switch 168 will change to HEX06 for airprint enabled or HEX 07 for airprint enabled. under admin -> network page 2 -> airprint will appear. looks like the machine needs to be on function ver 7 to work with LK.
      Very nice feature to use with apple. Once the machine is setup the rest is easy, much better than the app!
      Whatever
      • allan
        RTFM!!
        • 5462
        Re: AirPrint
        Any body know of a type of airprint server to use for older machines?
        Whatever
        • SmellsHot
          Head Tech
          • 512
          Re: AirPrint
          Allan,
          when airprinting did it seem to lock up your phone or at least take awhile to print out? A couple of my boxes seemed to struggle with it....
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • havokprod
            • Oct 2012
            • 159
            Re: AirPrint
            I have used these devices for older MFPS
            xPrintServer - an iOS Print Server for iPhone and iPad Printing
            • Gino_21665
              • Feb 2014
              • 15
              Re: AirPrint
              Hi
              I know this thread is a bit old however i have a question, If i am already able to print out of the Airprint App on my Iphone, i suppose the Airprint function is active on the printer. Never did any Firmware or Jumper settings by default it worked, problem is that when i use the app i am unable to edit or change any print option when using it.
              These are my Specs :
              Bizhub 223
              Printer firmware : Please see attached doc
              MAC notebook Model and Software Ver :
              iMac (21.5 inch, late 2013)
              OS X Yosemite version 10.10.1
              Iphone Model and Software Ver :
              iPhone 6S
              9.2.1
