C6500 Calibrating Too Much!
  • dagoof
    Still learning...
    • 220
    Got a c6500 that perpetually seems to be calibrating - we're talking every couple of hundred sheets. I've tried adjusting some of the dipswitches on #23 but can't seem to limit it. I also ran the recommended initial setup procedure, but it's not abating.
    Can anyone help?
  • dagoof
    Still learning...
    • 220
    Re: C6500 Calibrating Too Much!
    Bumping an old thread to see if anyone else had any ideas?
    On this machine, the waste toner pipe had compacted and I cleared it not that long ago - within a matter of weeks it's compacted again.
    But also, the machine is eating yellow toner at an alarming rate, wondering if it's related?
    • sadanand
      • 62
      what is pm status
      • dagoof
        Still learning...
        • 220
        Just replaced drums & coronas Sadanand - dev's getting close to needing replacement though.
        The rate of eating toner is new but this machine's always ran calibration far too frequently.
        • sadanand
          • 62
          If developer is more than 130% then replace all developer also how much a4 you are getting in one bottle
          • dagoof
            Still learning...
            • 220
            Dev is only about 85% - got about 5k sheets off the last bottle and we're talking very low coverage (under 5%).
            • sadanand
              • 62
              [QUOTE=dagoof;537330]Dev is only about 85% - got about 5k sheets off the last bottle and we're talking very low coverage (under 5%).[/QUOTE
              check calibrating sensors and problem seems with yellow dev if chinese it will create this problem also cross check efi 1000
              • dagoof
                Still learning...
                • 220
                On the color reg assembly?
                Just did an 'initial setup' routine on it and calibrated to controller with spectro. Have always done this on PM, it may sort toner use (we'll see) but, going from past experience, it won't sort the auto calibration frequency!
                • sadanand
                  • 62
                  Calibration process means adjusting difference between factory setting and actual machin values I once had same problem
                  but resolved by changing reg assembly and updating firmware
                  • dagoof
                    Still learning...
                    • 220
                    Yeah, thanks, my guess was it's a firmware issue.
                    • dagoof
                      Still learning...
                      • 220
                      Hmm, checked and it's v60 f/w so I don't think that was the issue. I did notice, however, on the Printer Gamma Offset Auto Adjust that the Y was running way too high
                      Also, colour reg assembly was as clean as I've seen one!
                      • sadanand
                        • 62
                        Sorry Did not get you quite busy with 6000 try exchanging y sensor with other preferably cyan
                        refer to page 141 in sm Theory of Operation Ver1.0
