Bizhub 421 C-3901 error
  • cap0319
    • Oct 2012
    • 34
    [Error Code] Bizhub 421 C-3901 error
    Hello all
    Got this error recently, steps taken so far are trouble reset, and I've replaced the fuser with a back up unit. Still getting the code. Are there any more steps to take before opening the machine to replace the PCRB/OCRB?
    If it was just thermister 1 acting funky I would have thought my back up unit would have solved the issue.
    any help is welcome!
  • CraigW
    • Dec 2010
    • 417
    Re: Bizhub 421 C-3901 error
    Did you set Switch 3 Bit 1 back to 0 ???
    • mo0651
      • 1054
      check your fuser connectors for bent or broken pins. Make sure connectors are not loose.
      • JR2ALTA
        • Feb 2010
        • 2017
        I am assuming the 1st reply is a way of saying "did you do a trouble reset"?? code won't go anywhere until you do a trouble reset
        • cap0319
          • Oct 2012
          • 34
          Thank you for the responses guys, I haven't done the dip switch, but I have done trouble reset through the service mode and on start up.
          I'll try the switch, check connectors again and then report back.
          • cap0319
            • Oct 2012
            • 34
            UPDATE:
            Set dip switch 3-1 to 0, no dice.
            trouble reset again, no dice.
            checked connectors on the fusing unit, I.E. the pins in the back of the unit + the ones on the machine, they look fine.
            moving forward with PRCB replacement
            • CraigW
              • Dec 2010
              • 417
              Lamps coming on before coding out ??
              • cap0319
                • Oct 2012
                • 34
                I don't believe so, then again I don't know an easy way to trick the machine and look internally to see it light up. I don't hear either fixing roller start to spin when it powers on. And I've been cautious when powering on by hitting the main switch, waiting a bit and then hitting the sub switch on the console. It throws the code pretty much immediately.
                • CraigW
                  • Dec 2010
                  • 417
                  You might Ohm out both thermistors, yellow leads better then white.
                  Never had luck removing crud from them safely.
                  Load check is #45 1-6 only run for a short bit (5-7 seconds) then touch upper fuser roller to test for heating.
                  • cap0319
                    • Oct 2012
                    • 34
                    Load check gives me nothing, no noise or start up of the fuser and it has no heat. Tried it multiple times to no avail.
                    at this point I've replaced the PCRB board and I still get c-3901.
                    So the last thing to try is OCRB and then?
                    thanks to everyone for the replies and have a Marry Christmas.
                    • Saghir377
                      • Feb 2013
                      • 47
                      Hi hope up to now you solve this matter don't take it serious its feeling like fixing unit is out of machine put it back then reset trouble hahaha its funny han.
                      Dear simple matter your heating lamps are not getting power reason might be thermal fuse wiring there is a power supply unit check up to now this machine have no issue like this
                      • allan
                        RTFM!!
                        • 5450
                        You would be able to feel the heat on the rollers after startup.
                        Whatever
                        • devil3000
                          Hello, did your friend handle this C 3901 error? Because I have the same problem and I can not do anything. It deletes the error and changed another fuscher and I changed the PCRB, and even the motherboard from another machine and the error goes back over and over again.
