C253
  • abraracoursix
    • Oct 2025
    C253
    Hello everybody,
    Some help for service code C-8103 in Konicaminolta C253 machine?
    This code not appearr in service manual.May be some problem with DF 605?
    Vero
  • JustManuals
    • Jan 2006
    • 9818
    You should read your manual more carefully. There are 4 references to this error in the 1177 page Field Service Manual. Since you have the manual already, no need for me to post the explanation here.
    Paul@justmanuals.com
    • abraracoursix
      thanks for your reply.
      Unfortunely for me it's seem your Field service manual is not the same I get.
      European one has ONLY 1028 pages.
      • JustManuals
        • Jan 2006
        • 9818
        Well I've added the Parts manual to the end of the Field service manual.
        • dallas
          • Jun 2008
          • 115
          DF-605 are the Document Feeder for Bizhub 250/350!
          C-8103: Lift up mechanism failure (DF-611).
          Fix: 1. Close the DF befor you turn on the main power switch.
          2. Change the Motor Assy for lift up the document feed tray (Parts Page 3/33).
          • abraracoursix
            Thank you very much Dallas! try it to morrow.
            • popcornpuppy
              • Jul 2008
              • 29
              you have to open up the document feeder until you can see the white lift up cam which is underneath the lift plate. what you need to do is slightly bend upwards the horizontal metal plate which supports the gear drive for the cam. i usually place 2 small cut outs of the c350/c450 cleaning material underneath to support it and prevent it from bending downwards again. also if the customer is turning on the machine with the document feeder in the up position it will cause the code, hope this helps
