C 6501 jam code 3152 (no paper inside)
  • selmila
    • Aug 2012
    • 133
    I dont see any jamed paper inside and i have also checked all sensors,wires and i have even swop the ADU of a working machine but the j 3152 shows.any suggestion to recover j 3252?
  • kalindd
    • Jun 2008
    • 192
    Re: C 6501 jam code 3152 (no paper inside)
    J-3152 - Fusing loop sensor (PS64) is turned on in the idling condition.
    Did you check the sensor?
    You've swapped the ADU, but did you swap the fusing unit? This sensor is located inside the fusing unit.
    It can get very dirty with paper dust and toner dust, just clean it.
    • methogod
      • Dec 2008
      • 915
      remove fuser
      take off infeed plate
      its the sensor with the flag right under it...
      make sure the spring is not broken. Clean sensor....
      Trace wire sensor to pin out, and make sure the pin is there and not broken off...
      sucks you pulled the ADU...
      good luck...
      • selmila
        • Aug 2012
        • 133
        Originally posted by methogod
        remove fuser
        good luck...
        Hi.
        i have checked everything related to the jam but it is PRCB malfunction!!
        I swop the PRCB in to a working machine and the working machine pops the jam code.
        Is there a chance to fix the PRCB?
        • methogod
          • Dec 2008
          • 915
          HYTEC (hytecrepair.com)
          as for VJ
