konica c360 black as priority
  • DOE
    • Mar 2010
    • 258
    is there any way to set black as priority when reset on a konica c360. for some reason customer wants it to be black and white unless he changes it to color and right now auto color is the priority. thanks. went through settings and could not find a way to change it
  • allan
    RTFM!!
    • 5462
    Re: konica c360 black as priority
    change the setting to black and white then go to > utility > user setting > copy setting > current setting. If you set the machine to black priority in service mode it only stabilize for black making the machine quicker. it will stabilize all colors if you select colors. Think that is under > Machine.
    Whatever
      • 15069
      Change softswitch 50 to 00000001. That will set it to black priority.
      Hope this helps.
