konica 550 c 3102
  • xzab
    • Nov 2014
    • 14
    [Error Code] konica 550 c 3102
    hello i have changed the fusing unit i reset the machine and still the code c3102 is on.please help
  • allan
    RTFM!!
    • 5462
    Re: konica 550 c 3102
    does the fusser heat up. any heat? power supply would be next.
    Whatever
    • xzab
      • Nov 2014
      • 14
      no it does not heat up.
      • padedwalls
        • Dec 2014
        • 40
        • padedwalls
          • Dec 2014
          • 40
          Pretty certain fuser error must be cleared for restart through "Trouble Reset"... good luck
          C3102 Fusing roller failure to turn • When the IH power supply is turned ON,
          pulse signals are not input either of the
          heating roller rotation sensor/1 or the heating
          roller rotation sensor/2 within a predetermined
          period of time.
          ⎯ A
          It is a hard down after fuser error! Did your old fuser shred? (fall apart? Bind motors?)
          • xzab
            • Nov 2014
            • 14
            i have done everything you say for the reset but it does not solve the problem..
            • padedwalls
              • Dec 2014
              • 40
              What was condition of old fuser? Failure cause?
              what i'm getting at is that it may be a drive issue...
              • padedwalls
                • Dec 2014
                • 40
                http://www.copytechnet.com/forums/ko...-c-3201-a.html
                perhaps of more use!
                Quick question????
                You use old web unit to new fuser? Been awhile since i touched this model, but i think web unit is independent unit from fuser from parts.... i suspect your web unit may be the "binder". I preferred to replace with new when doing a fuser unit!
                • xzab
                  • Nov 2014
                  • 14
                  press roller of the old fuser was broken on the one side..
                  • padedwalls
                    • Dec 2014
                    • 40
                    sorry about above ^^^ I'm thinking of earlier models with a wet fuser
                    • xzab
                      • Nov 2014
                      • 14
                      ok thank you
                      • padedwalls
                        • Dec 2014
                        • 40
                        Right door switch operation ok?
                        how ironic a branch email just came out from a senior tech about KC454 with C3201... he's looking for answers too!
                        "keeps coming back"
                        says his fuser is not binding & next is drive motor then PRCB....
                        good luck!
                        Service manual shows point to point connction checks when lamps don't come on pg 738 of 1501 pg pdf
                        • padedwalls
                          • Dec 2014
                          • 40
                          There's a motor M17 in rear machine far right of main drive unit same part # as fuser drive motor... can swap for troubleshooting (if motor error moves to main drive error, then its motor).... also check to see if all vertical & registration roller(s) moving freely. New 4/5/6/7 series have bushing tie ups causing fuser/transport drive seizure! Not sure if these older fuser motors drive vertical!
                          • allan
                            RTFM!!
                            • 5462
                            The Fuser gets regulated by power supply. Got this alot on B250 machines changing power supply fixed the issue.
                            Whatever
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              regarding 4 series with this code randomly appearing and not due to paper jams, its the fuser drive motor, we have had it several times.
                              regarding what i presume is a bizhub C550, if the error has been reset and keeps coming at random with a new fuser it wil be the rotation detection sensor housing and photo sensors. replace them all. I've had this before and pulled plenty of hair out because of this.
