C35 Error 0094
  • earney
    • Sep 2014
    • 28
    C35 Error 0094
    I have a C35 that is now displaying error 0094. I had originally attended due to colour registration issues (no error code) so had cleaned the lasers and removed transfer belt checked all ok re-assembled and realised the right door was stiff to close. This was an issue that we had noticed before but a good shove got it closed. It is still hard to close but now displays the error 0094.
    Following advice I found online I have removed the pad from the 2nd transfer solinoid and checked the springs on the door but still same issue. Im assuming its due to the door. Any advice?
  • Gift
    • Mar 2011
    • 2459
    Re: C35 Error 0094
    Yeah we've went that way, too and ended up swapping the right door assy to fix 0094
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Re: C35 Error 0094
      make sure the idc sensor shutter is opening properly - it is a piece of crap and there is a bulletin on it.
      If the idc shutter does not open the machine assumes the transfer roller pressure/retraction operation is not successful - this is how it tells the operation is completed as its the transfer roller that opens it.
      Dont know about the stiff to close door, that is perhaps because the transfer roller has stopped in the pressed position.
      • earney
        • Sep 2014
        • 28
        Re: C35 Error 0094
        Yeah the shutter opens OK manually by hand using the actuator on the right. However if the issue is with the door it may not be opening via the gear system on the door itself. It's hard to tell. I can hear the solenoid clicking away once the machine boots up then displays the error. I'll check later by marking the gear to see if it's actually turning once the door is closed
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: C35 Error 0094
          C35 door replacement is a PITA, it is actually easier on the C25 oddly enough. Hope you dont need to change it
          • mo0651
            • 1054
            Re: C35 Error 0094
            You mentioned that you had removed the transfer belt.... Did you get the plastic guide back into position? It's the one you lower out of the way... it makes the door hard to close.
            • earney
              • Sep 2014
              • 28
              Re: C35 Error 0094
              Not sure exactly what one you are talking about? Is it the guide that houses the IDC sensor?
              • earney
                • Sep 2014
                • 28
                Re: C35 Error 0094
                • earney
                  • Sep 2014
                  • 28
                  Re: C35 Error 0094
                  Thanks, got it sorted. Way back when there were image problems maybe 2 years ago the transfer belt was removed. The guide below that houses the IDC sensor was left in the lower position hence the door hard to close. Couldn't tell you how it has worked for two years but it's sorted now in the upper position the error has now disappeared and prints are perfect. Noob error [emoji20]
                  • mo0651
                    • 1054
                    Re: C35 Error 0094
                    YEP!!! YOU GOT IT!!! Crazy little cover.
                    • allan
                      RTFM!!
                      • 5462
                      Re: C35 Error 0094
                      Had a broken transfere roller retraction gear cause this once machine can not open the sensor shuter. Q-bond works magic. the duplex units screws also break out.
                      Whatever
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        Re: C35 Error 0094
                        WTF, I didn't think you would be able to close the door like that at all.
                        • allan
                          RTFM!!
                          • 5462
                          Re: C35 Error 0094
                          Sorry not the screws the plastic hooks keeping it assembled
                          Whatever
                          • fin
                            Re: C35 Error 0094
                            Hi guys, have had the same error code on the c35 twice in the last year, with the shaft breaking causing for the error code 0094 i know that if i was to replace the door the error code would be removed but this would only be a short term fix as the shaft will break again, i was wondering if anyone has an idea of what could be causing the shaft to break so regularly
