C6500 Fuser breaking gears
  • Joseph.ARM
    • Jun 2013
    • 36
    Afternoon everyone,
    TGIF! I'm having an issue with a fusing unit for a c6500, its breaking teeth off of Fixing Drive Gear /F 20/28T A03U808600.
    I've replaced the gear below it Fixing Drive Gear /B 28T A03U808201 it had a lot of play on its shaft thinking that would fix it but its still breaking teeth off of the white gear.
    I just noticed when the fusing rollers are under pressure the space between the gears increases, I'm guess that's breaking the teeth.
    Just FYI, the 3 one way bearings have been replaced, Fixing Driving Gear /M 22T A03U809311, but not by me.
    Has anyone seen this before or know what might be causing it? Thanks in advance.
  • bizhub1
    • Sep 2008
    • 230
    Re: C6500 Fuser breaking gears
    my guess is the one way on the upper roller is on backwords.
    • Mick01
      • Nov 2012
      • 362
      Hi,
      Bizhub one is spot on with his advice.
      The one way gear will be on backwards. Causing the roller to lock when it is trying to drive.
      • PeterG
        • Jul 2008
        • 177
        Originally posted by Mick01
        Hi,
        And we have all done that, at least once in our lives. Haven't we!
        Hi Mick. Its Peter, from Bendigo.
        • Joseph.ARM
          • Jun 2013
          • 36
          You got it! It was on backwards.
          Another one of those things you can't find in the manual, just have to experience it.
          Thank you! I appreciate your help!
          Joseph
          • Joseph.ARM
            • Jun 2013
            • 36
            Hi,
            Makes sense and explains why it only broke under pressure.
            • mikeena
              Branch Technical Manager
              • Mar 2007
              • 219
              lol i went through three gears one day and then realized maybe its not the machine. Maybe it was somethig i did before i put it back together. I was taunted for weeks at my office
              • gisburn20
                I did this on my first ever Solo PM on a 6500, ever since then I've carried that gear as a spare, just in case.
                I haven't done it since, but I've followed behind a few engineers who have!
                Jim.
                • methogod
                  • Dec 2008
                  • 917
                  Needed this laugh...
                  i would think after 1 gear, you would hand turn the motor, both ways. but maybe that's just me - funny in a not so funny way.
                  I have had gremlin's in a machine that we just trashed after putting a few hundred into it...
