Wireless Network Adapter
+ More Options
Posts
  • copierwhisper
    • Mar 2013
    • 78
    Does anyone know if a wireless network adapter (usb) can be plugged directly into a C360 to allow various computers in the building to print and scan?
  • emujo
    • Jun 2009
    • 3009
    Re: Wireless Network Adapter
    Try it and let up know...you can also run a Ethernet cable from the MFP to a wireless access point, looks like wireless printing to any end user. The newer 3 series have the UK-208 (built in wireless adaptor) if upgrade is an option. Emujo
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Netgear makes a nice little wireless adapter, that you connect to the wifi and then via cable to the copier for wireless access. wnxx 3001 I beleive. They work well................and their not expensive.......................
      Mystic Crystal Revelations
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        I can't imagine that approach even possibly working. Not a supported OS, no drivers, etc...
        The good news is that a bridge or even a range extender costs very little more than a USB wireless adapter.
        • wseyller
          • Sep 2012
          • 1129
          What Kenb said...
          Yeah the copier would need a driver and os functionally to be able to use it so answer is NO. I think wireless on a copier is not the best idea unless there is just no other way. I see businesses spend thousands on a copier and don't want to spent a little money running a network drop. If you need wireless then buy a network bridge to transform wired connect from the copier to wireless.
