Re: Registration Problem
MGI incorporates their own software into the firmware. So through a computers "MGI Pilot" application you can manually adjust the C450's THV and the fuser temperature as well as the press feed speed. You can run just about anything through the machine. Including vinyl, teslin, PVC paper and even metallic stock. I haven't seen any P code popping up. If there is a way of bringing up the past history of error codes, that is something I'm not aware of. In addition we've been doing a lot of testing with various stock weights and sizes. It seems that registration problem is mostly limited to the 11" x 17" size in any stock weight. Perhaps the feed rollers in the paper transport are worn but the seem OK.
