Obscure Part, Tough to find, C360
  • pgramolini
    • Sep 2014
    • 19
    Hi All,
    Trying to find a part number for a C360. It is the latch that the top right door pawl latches onto, it also allows the interlock of the right door to actuate the switch to tell the machine the door is close...it's like trying to find a needle in a haystack. Looked in vertical conveyance section, vertical conveyance door section and paper exit section. Wondering if anyone has ever replaced this and knows where in the parts manual it is... Thanks!
  • hotfuser
    • 180
    Re: Obscure Part, Tough to find, C360
    Originally posted by pgramolini
    Hi All,
    The part number i think you require is A0ED102800 (holder) it is on the PH section item number 7
    • pgramolini
      • Sep 2014
      • 19
      Thanks much. Found it.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        yep, i took forever to find that the first time too.
        technically it is user abuse too, because that is not an easy part to break.
        • pgramolini
          • Sep 2014
          • 19
          They must have slammed that thing extremely hard. It was mangled. They bent the frame. 3.5 hr call. Yech
