Mishandled paper j10-01 c500
  • billy39
    • Dec 2014
    • 17
    Hi, I am having a problem feeding any type of paper / size via the bypass. I am getting error message mishandled paper j10-01 error. Any help advice is much appreciated
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 219
    Re: Mishandled paper j10-01 c500
    sorry the c500 is so old it is hard to remember what exactly it looks like. Ill try my best though. Here is what i found on konica
    Solution ID
    TAUS0801283EN* Solution Usage
    Description
    J-1001.
    Solution
    CAUSE:Paper stopper plate failure (for the paper stopper plate position,)
    SOLUTION: Check whether the steel plate isdamaged ormalformed. If the plate has failed, replace (p/n 65AA42221E).
    I have had this issue on new models and had the clutches be the problem however dont know if it is the same as the 500. konica refers to a attachment regarding this issue on there website but i cant find it lol. good luck
