Bzhub Pro C6500 with Error C-2422
  • qantas
    • Jul 2012
    • 23
    Hi Senior,
    Machine has been in the warehouse nor working for 2 years, before everything alright.
    Been trying to set it up,
    First error was C 4520 and can be fix.
    Now C-2422 , been trying :
    IO 54 CMY - only less than 30 , black is good for 120
    How to solve this C-2422 error please
    thks
  • Joseph.ARM
    • Jun 2013
    • 36
    Re: Bzhub Pro C6500 with Error C-2422
    Originally posted by qantas
    Hi Senior,
    thks
    C-4520 - clean the color registration sensors.
    C-2422 - pull the magenta developer unit and clean the TCR sensor. IF that doesn't fix c-2422 switch the magenta unit with one of the others, to see if the code follows the developer unit. If it does the sensor is probably bad. ***Put tape over the developing unit when you switch them so you do not get the wrong toner in there.
