Bizhub scanner/ADF out of alignment?
  • ECA
    • Dec 2014
    • 61
    Hi guys
    Another question, for the Bizhub C552.
    ive noticed the ADF scans/copies with some wrapping/bluring on the pages.
    im assuming this is due to the ADF cover is not correctly aligned. or there is a gap.?
    I need to know if i need to adjust the hinges of the ADF top?
    When the top is shut it has a 1cm gap at the back where the hinges are.. but the front is flush. see picture of what i mean...
    Is this correct?
    also is the top lid fully in line with the bottom of the printer? as it seems offset... aka the footprint is flush with the printer casing below..
  • habik
    • 2013
    Re: Bizhub scanner/ADF out of alignment?
    Hope this helps.
    Firmwares HERE
    • ECA
      • Dec 2014
      • 61
      Originally posted by habik
      Hope this helps.
      [ATTACH=CONFIG]27653[/ATTACH]
      Thx can u upload again? Its just blurred image
      So im guessing it needs to be flat on glass??
      • habik
        • 2013
        Hope this helps.
        Firmwares HERE
        • allan
          RTFM!!
          • 5462
          use a piece of paper 1 inch wide folded four times. Put that at both sides front and rear of slit glass, it must pull out with the same amount of tension then the DF would be perfect.
          Whatever
          • ECA
            • Dec 2014
            • 61
            thanks all. sorted. must of moved when getting the beast up stairs to the forth floor!!
            • Northwestservice
              • Jan 2011
              • 140
              that interesting because i was going to ask what has been done for the df to be out of postion
